Machine Vision
Vision
Just a quick question, does "image control display" come with labview/vision assistant evaluation? In the vision utilities  palette I can not find it. I am looking to display the image on the block diagram.
Damien
(4,731 Views)
This control coming with either Vision Acquisition Software or with Vision Development Module.
This is display for Front Panel. You can't display image on the Block Diagram.
(4,728 Views)
I have activated the vision development module,  so do i use the vision acquisition vi under vision express. Yes I am looking to display it on the front panel,
Damien
(4,727 Views)
Accepted by topic author Damien129
Hi Damien,
Thanks for your post. Please see this article that explains more about the Image display control: http://digital.ni.com/public.nsf/allkb/1A0508DA3EAD0DA986256DB700704B58?OpenDocument
You will need Vision Acquisition Software, also referred to as NI-IMAQ in order to see this control on your front panel. Here is a link to where you can download this from: http://joule.ni.com/nidu/cds/view/p/id/2975/lang/en
Hope this helps.
Kind regards,
Mahdieh G
National Instruments UK&Ireland
(4,713 Views)
You do not need to install Vision Acquisition to get the Image Display control (though that is one way to get it). It is also installed by Vision Development Module.
I suspect the issue is that you are looking at the palette on the block diagram, when really you need to look at the palette for the front panel (as it is the same as any other control/indicator).
Eric
(4,698 Views)
