Machine Vision
Vission Assistant extended Evaluation
Is it posssible to get a 7 day Vission Assistant evaluation extented to 30 or 45 days?  The Eval copy was downloaded from NI.com so I cant register by serial number to extend the eval period.  Is there an eval serial number that would inentify the eval version?
The Machine ID is:
S6LJ-WFJ8-VRBM-BHV2.
(You could just PM me the SN and activation code THANKS)
Your Champ-
(4,231 Views)
The initial evaluation period is 7 days and is then extended to 30 days after you register the software using your ni.com profile. This will most likely be done through your NI Vision Development Module rather than the Vision Assistant specifically, since the Vision Assistant comes with the Vision Development Module. Unfortunately, there's not a serial number for the evaluation version. I hope this is helpful.
Blake C.
www.ni.com/support
(4,212 Views)
Not really Blake,  I cant register the Vision Assistant without a serial number (I'm good to go with a forum profile though!) the NI Vision Development
(Full) has a valid license so that does not seam yto help
(4,199 Views)
Jeff,
Normally the Vision Assistant is linked to the Vision Development Module and having an active VDM license should provide you with an active Vision Assistant. At this point it would be best for you to call our support engineers in order for us to look up your serial number and specifics about your account to see what’s going on at a deeper level. Our support engineers can be reached by calling 866-ASK-MYNI (866-275-6964).
Blake C.
www.ni.com/support
(4,188 Views)
Will do in the morning...I figured it would be a "call me now" fix
I just wish I could get the employees at (A Silver Alliance Partner) too get with the program.  Much appreciated!
(4,185 Views)
