Machine Vision
W5500 Crystal Frequency Question
Hi, we have a product that uses W5500 as the Ethernet controller. But we are running out of stock of the crystal that connects to pin 30 and 31. We see from the datasheet that the requirement for the crystal is 25MHz. Can we use some other frequency like 24MHz (lower) or 30MHz (higher)?
(2,375 Views)
Could you please explain why this electronics question is posted on a NI Discussion forum under the Machine Vision board?
Santhosh
Soliton Technologies
(2,358 Views)
