Machine Vision
We are using vision assistant and we don't no which the best function we can use for our product
pass Pass   " the camera from the top view"
fail Fail 1
fail 5.png Fail 2
fail 6.png Fail 3
fail 7.png Fail 4
fail 8.png Fail 5
fail 9.png Fail 6
(3,114 Views)
What is the criteria for failing? the circularity of the ring and presence of the "DO NOT EAT" label?
It is not clear to me why #2, 4, 5 and 6 are failing.
(3,111 Views)
Hi Christophec,
Fail 2.png Fail 2 has outside edge
(3,102 Views)
Fail 4  there is damage in the paper do no eat
Fail 5  also you will found damage in the paper from the lift side
Fail 6  I know this is the difficult one because the capsule is closed right but there is gab between the close edge and the paper and you will see it as a shadow.
(3,101 Views)
