Machine Vision
What can I do to work with leadtools and IMAQ products?
I'm a Microsoft Visual Basic Developer and I'm trying to work with IMAQ devices and ActiveX libraries such as LeedTools. My problem is that this ActiveX objects need to work with TWAIN devices and National Instruments doesn't support TWAIN's standard.
(2,948 Views)
Lucas,
NI's IMAQ products do not provide TWAIN support in their drivers, as to be called using the TWAIN protocol. There is a company called Graftek, www.graftek.com that has some LabVIEW TWAIN drivers. They might be able to give you a closer suggestions for solutions. But our boards do not support or are supported under the TWAIN protocol.
Good luck!
Nestor.
Nestor
(2,948 Views)
