Machine Vision
What is PCI1409 PCLK OUT hardware spec?
I have a scanning instrument that makes an HSYNC (500ms period), VSYNC (500usec period, phase locked to the line frequency, 60hz), and four video signals without timing information. No pixel clock is available. I would like an image that is roughly 1024x800 pixels
I have pulled the W1 jumper to use differential mode for ground loop noise immunity.
Can I use the External Lock Line Scan Camera mode if I strap PCLKOUT to PCLKIN? I am unsure whether to strap +- to +-, + to + with - to - to gnd, or pclkin - to gnd and pclkout- open circuit. Obviously I don't want to gnd pclkout - if both pclkout+- lines are driven by low impedence amplifiers.
And what are the output impedences of such amplifiers?
Is pclkout capable of driving
a 75ohm sink?
Will pclkout be phase locked to HSYNC?
NI Software : Measurement Studio for Visual C++ Version Measurement and Automation Explorer
NI Hardware : Image Acquisition (IMAQ) device PCI-1409
Driver Version : 2.5.1
OS : Windows 2000
CPU : Pentium
RAM : 512M
Vendor : IBM M Pro Intellistation
Customer Information :
Philip Batson
IBM
batson@us.ibm.com
(2,984 Views)
Have you looked at the following documents,
http://zone.ni.com/devzone/conceptd.nsf/2d17d611efb58b22862567a9006ffe76/e0b9712bb1f4d8e286256a390066a3fb?OpenDocument
http://digital.ni.com/public.nsf/websearch/B7F94A4C7897992386256A780069A436?OpenDocument
BTW, the latest IMAQ driver is 2.5.5,
http://digital.ni.com/softlib.nsf/websearch/42AB44A5B0854E6086256C0E004E3D87?opendocument&node=132060_US
I'm also going to email you some more info at batson@us.ibm.com
(2,984 Views)
