Machine Vision
What is wrong in Loading the Imaging Source LabView Extension, on CVS-1450
Dear
We have bought a CVS-1450 Module to handle the imaging and processing parts of our
project easily. We have two analog camera. By using the Imaging Source Video-to-Firewire converter
we connect them to the CVS-1450. Unfortunately, the IMAQ 1394 package does not recognize this convertor,
because the output of this convertor is not DCAM. This company have a LabView Extension Toolbox which makes it possible to connect
to that converter in PC. But I can not load this Library (or its sample codes) to the CVS-1450. It returns a message such as "failure to load"  the desire .vi
and then "can not load" the related .dll, when I try to do it.
It is very  important and critical for us to solve our acquisition problem.
Please help us.Thanks a lot.
Best Regards.
Keyvan Arj
Beena Vision Inc.
(3,156 Views)
Hi
The problem you are having is that the dll it is trying to load is a Windows based dll and therfore will not operate on a CVS, as this runs a real time OS called Pharlap. I would suggest getting two DCAM compatible cameras to replace your analogue cameras and converters.
If you can reply with the resolution, frame rates and bit depths that you need then I can try and point you in the direction of some compatible cameras.
Hope that helps
Mike
(3,152 Views)
