Machine Vision
What's the difference between HSL and HSI in assistant7.1?
Maybe, it's a simple question but I really want to know it.And in color space of image, how can I obtain the value of 'L' from the values of RGB? Who can tell me???
Thanks!!!
(3,977 Views)
Hi..
You can extract a single plane of 8-bit Luminance from an input of RGB color image. There is a vi used to extract any single color plane you want..Did I solve your problem?
Message Edited by liaw82 on 04-09-2005 08:06 AM
(3,961 Views)
Hello interisting,
Here is some more information:
HSL = Hue Saturation and Luminance
HSI = Hue Saturation and Intensity
Luminance: A measure of the amount of light reflected from a hue. Those hues with a high content of white have a higher luminance or value.
Intensity: Is how light or dark a color is.
liaw82 was correct in saying there is a function to extract the luminance plane from a RGB image. If you look under the "Processing Functions: Color" of Vision Assistant, you will find an extract color plane section. In there you will find "HSL-Luminance Plane"
Nicholas C
Applications Engineering
(3,937 Views)
thanks!
that's what i want!
(3,919 Views)
