Machine Vision
What version(s) of PCI specification does the NI 1428 comply with?
The NI 1428 specification does not say what versions of the PCI spec it is compatible with.  NI 1428 specifies 5 V and +/- 12 V supplies but from what I know versions 2.3 and 3.0 of the PCI spec require 3.3 V power supply compatibility.  What PCI version is the NI 1428 and does it properly support 3.3 V supply voltage?
(3,110 Views)
Hello Image_maker,
Most of current NI PCI devices support both 5V and 3.3V PCI/PCI-X standards. You can tell the difference by looking at the keying on the device. For PCI-1428, it has universal PCI which would support both 5V and 3.3V standards. You can refer the the knowledgebase article below for reference.
Will a National Instruments PCI Board Work in a PCI-X Bus?
http://digital.ni.com/public.nsf/allkb/CA50CE155A00436086257163006B9F39?OpenDocument
Andy Chang
(3,091 Views)
