Machine Vision
When I use IMAQ WindDraw Function,error ERR(-1074396157) occur
When I use the IMAQ WindDraw function, an error occur with the following error code: ERR (-1074396157). Why this error occur and what is the possible reasons for this type of error? Also how to solve this type of error?
(3,453 Views)
b_rani -
Error -1074396157 (as mentioned in the documentation) corresponds to "Unlicensed copy of IMAQ Vision." This could happen because you were using IMAQ Vision in evaluation mode, and the 30 days have expired. If you run the NI License Manager, you should be able to see the status of your licenses and figure out what's going on.
Greg Stoll
IMAQ R&D
Greg Stoll
LabVIEW R&D
(3,450 Views)
