Machine Vision
Where can I find ImageToArray Example.vi?
Hello,there.I am trying to use "ImageToArray Example.vi" to exact an optical intensities matrix from IMAQ using LabView. I can't find it from "examples\vision\2. Functions\Image Management\
",since in my "examples" there is no "vision" folder.And I downloaded one from your website,but it's in CVI form.I don't know how to run it in LabView or where can I get a VI form directly. Thanks in advance.ellen
(4,645 Views)
I think you have to enable examples check box during the installing your Imaq Vision to get vision folder in examples. Anyway this VI is simple to use you can try it out yourself. I have attached that VI which can help you. I think that vi gives the pixel values near to the points where you click. If you are not wiring the optional rectangle it will give the whole image pixels array.
Hope it helps you.
(4,645 Views)
Hello Ellen.
Indeed as was previously mentioned, the lack of this example VI is due to the fact that you do not seem to have the LabVIEW examples installed on your machine. If you re-run the Vision installer, you can be sure that 'Support for LabVIEW 7.0 (or other versions)' is checked. The installer will then place the example VIs in the folder you were mentioning above.
Colin C.
Applications Engineering
Colin Christofferson
Community Web Marketing
Blog
(4,645 Views)
