Machine Vision
Where is Vision Run-Time 8.6.1?
Colleagues, here is a very simple question.
I have installed LabVIEW 8.6 / Vision 8.6.0.
Then Vision 8.6.0 was upgraded with Vision 8.6.1
But when I building installer in LabVIEW 8.6, then Vision RunTime 8.6.0 only available (and on the target machine we've got 8.6.0 DLLs, of course).
Is somewhere Vision RunTime 8.6.1 available? Or I should overwrite some DLLs in System32 folder manually?
Thank you in advance,
Andrey.
(3,631 Views)
Hi Andrey,
      I believe that they haven't released updated runtime engine yet, but do you need Version 8.6.1? . In other words, does your work were affected by version 8.6.0 so that you had to use the minor update to fix it?
     Perhaps it is fast remedy to use 8.6.0 til the runtime engine release if it doesn't affect your work.
Waleed El-Badry MSc.,MCPD, ISTQB Certified Tester
Assistant Lecturer
Mechatronics Department
Faculty of Engineering
Misr University for Science & Technology
View Waleed El-Badry's profile on LinkedIn
(3,594 Views)
In general I prefer to have the latest version with some fixes...
Especially this exactly what happened: "When using dual monitors, the Open and Cancel buttons in the Select an Image File dialog box may not appear in their correct positions". We using dual monitors, and was unable to use Select an Image File function...
and this also not so bad: "There is a memory leak in the IMAQ Read Image And Vision Info VI."
Andrey.
(3,592 Views)
Hey,
It will be released in 1-2 weeks.
Christian
(3,576 Views)
