Machine Vision
Who can i get and save image by using driver for 3rd part camera?
I have a camera from Phytec company, and I would use this camera to acquire a film (continues number of image for a limited time) to a movement heart valve. The problem is: I am a beginner in this field, so I want to know how I can get the image and how I can save it and load it after a while.
Note, I download the IMAQ 3,0 from internet and i also have IEEE 1394 Version.
(2,784 Views)
If it is a firewire camera, you could use a sequence to acquire a series of consecutive images.
If it isn't, you either need to get an NI board that will connect to the camera so you can use IMAQ, or you will need to use the drivers that come with the camera. It is usually much easier to use NI drivers than to try to figure out how to get the third party driver to interface with LabVIEW.
Bruce
Bruce Ammons
Ammons Engineering
(2,768 Views)
