Machine Vision
Why can't I found Vision functions in Labview8 function panel after installing Ni Vision Develope Module 7.11 on win 2K?
Hello Guys,
  I tried to install NI Vision Develope Module 7.11 on win 2K after I installed Labview 8 PSD, but after I finished installation of Vision Develope Module 7.11 , I can not find any vision functions in function panel, can any body tell me why? Thanks.
(3,262 Views)
Run the attached file or copy the files manually:
All mnu-Files for die VIs are installed in
C:\Programme\National Instruments\LabVIEW 8.0\menus\default\vision
instead of
C:\Programme\National Instruments\LabVIEW 8.0\menus\Categories\VisionMotion
and Controls in
instead of
C:\Programme\National Instruments\LabVIEW 8.0\menus\Controls
So the VIs and Control are in vi.lib but there aren't seen in the palettes
Workaround:
Manually copy all file of
C:\Programme\National Instruments\LabVIEW 8.0\menus\default\visions
in
regurds,
Steffen
(3,234 Views)
