Machine Vision
Why can't I run the opencv dll?
My parameter are imagein1, imagein2, outputstr.
And the debug and release for making dll was successful.
But when I try to test it simply, an error occurs, I can't run.
<The library specified for this node cannot be found or cannot be loaded. Right-click the Call Library Function node and select Configure, then choose the correct library name or path.>
There is no problem with the path.
#include "rapid-af.h"
#include <chrono>
#include <opencv2/opencv.hpp>
using namespace cv;
using namespace std;
using namespace rapid_af;
extern "C" __declspec(dllexport) int __cdecl main(unsigned char* imagein1, unsigned char* imagein2, String outputstr);
Mat merge(Mat image1, Mat image2, Point2f shift);
BOOL APIENTRY DllMain(HMODULE hModule,
                       DWORD  ul_reason_for_call,
                       LPVOID lpReserved
    return TRUE;
__declspec(dllexport) int __cdecl main(unsigned char *imagein1, unsigned char *imagein2, String outputstr)
    Mat image1(2048, 2048, CV_16U, &imagein1[0]);
    Mat image2(2048, 2048, CV_16U, &imagein2[0]);
    const String keys =
        "{help h usage ?     |      | print this message}"
        "{@image1            |      | image1 for alignment}"
        "{@image2            |      | image2 for alignment}"
        "{mt-enable          |true  | enable multithreading}"
        "{o output           |      | path of debug output image}"
        "{p padding          |100   | search range for alignment in px}"
        "{pf-enable          |true  | enable prefiltering}"
        "{pf-ksize           |20    | prefilter gaussian kernel size}"
        "{pf-sigma           |5.    | prefilter gaussian kernel sigma}"
        "{agreement          |5     | agreement threshold in px}"
        "{q                  |true  | check image quality before alignment}"
        "{q-std              |0.1   | quality check: minimum standard deviation}"
        "{q-sratio           |1e-4  | quality check: minimum spectral ratio (within annular ring)}"
        "{q-sratio-radius    |30    | quality check: radius for spectral ratio}"
        "{q-sratio-thickness |5     | quality check: thickness for spectral ratio}"
        "{bin-enable         |true  | enable binary thresholding}"
        "{bin-threshold-perc |0.6   | binary threshold percentage}"
        "{dog-enable         |true  | enable Difference of Gaussian}"
        "{dog-ksize          |100   | DoG gaussian kernel size}"
        "{dog-sigma1         |5.    | DoG gaussian kernel sigma1}"
        "{dog-sigma2         |10.   | Dog gaussian kernel sigma2}"
        "{canny-enable       |true  | enable edge detection (8 bit only)}"
        "{canny-ksize        |29    | canny gaussian kernel size}"
        "{canny-sigma        |20.   | canny gaussian kernel sigma}"
        "{canny-alpha        |0.    | canny alpha param}"
        "{canny-beta         |1.    | canny beta param}"
    //CommandLineParser parser(argc, argv, keys);
    CommandLineParser parser(0, {}, keys);
    parser.about("RAPID-AF demo");
    String image1String = parser.get<String>("@image1");
    String image2String = parser.get<String>("@image2");
    if (parser.has("help") || image1String == "" || image2String == "") {
        parser.printMessage();
        exit(EXIT_FAILURE);
    struct Options opt;
    opt.multiThreading = parser.get<bool>("mt-enable");
    opt.padding = parser.get<int>("padding");
    opt.agreementThreshold = parser.get<int>("agreement");
    opt.bin_enable = parser.get<bool>("bin-enable");
    opt.bin_thresholdPercentage = parser.get<double>("bin-threshold-perc");
    opt.dog_enable = parser.get<bool>("dog-enable");
    opt.dog_ksize = parser.get<double>("dog-ksize");
    opt.dog_sigma1 = parser.get<double>("dog-sigma1");
    opt.dog_sigma2 = parser.get<double>("dog-sigma2");
    opt.canny_enable = parser.get<bool>("canny-enable");
    opt.canny_ksize = parser.get<int>("canny-ksize");
    opt.canny_sigma = parser.get<double>("canny-sigma");
    opt.canny_alpha = parser.get<double>("canny-alpha");
    opt.canny_beta = parser.get<double>("canny-beta");
    auto begin = chrono::steady_clock::now();
    double stdVarThreshold = parser.get<double>("q-std");
    double sRatioThreshold = parser.get<double>("q-sratio");
    int radius = parser.get<int>("q-sratio-radius");
    int thickness = parser.get<int>("q-sratio-thickness");
    if (parser.get<bool>("q")) {
        if (!checkImageQuality(image1, stdVarThreshold, sRatioThreshold, radius, thickness)
            || !checkImageQuality(image2, stdVarThreshold, sRatioThreshold, radius, thickness)) {
            cerr << "Error: Low image quality (-q option)" << endl;
            exit(EXIT_FAILURE);
    Mat i1, i2;
    if (parser.get<bool>("pf-enable")) {
        Mat filter;
        int ksize = parser.get<int>("pf-ksize");
        double sigma = parser.get<double>("pf-sigma");
        mulTransposed(getGaussianKernel(ksize, sigma), filter, false);
        filter2D(image1, i1, -1, filter);
        filter2D(image2, i2, -1, filter);
    else {
        i1 = image1;
        i2 = image2;
    bool ok;
    Point2f shift = align(i1, i2, opt, &ok);
    auto end = chrono::steady_clock::now();
    cout << "Shift: " << shift << endl;
    cerr << "Elapsed time: " << chrono::duration_cast<chrono::milliseconds>(end - begin).count() << "ms" << endl;
    if (!ok) {
        cerr << "Agreement threshold not met" << endl;
    String output = parser.get<String>("output");
    if (output != "") {
        imwrite(output, merge(image1, image2, shift));
        cerr << "Saved debug image to " << output << endl;
    outputstr = output;
    return 0;
    Mat M = Mat(2, 3, CV_64FC1); // Allocate memory
    M.at<double>(0, 0) = 1;  //p1
    M.at<double>(1, 0) = 0;  //p2;
    M.at<double>(0, 1) = 0;   //p3;
    M.at<double>(1, 1) = 1;   //p4;
    M.at<double>(0, 2) = shift.x;   //p5;
    M.at<double>(1, 2) = shift.y;   //p6;
    Mat shifted;
    Mat channels[3];
    channels[0] = Mat::zeros(image1.size(), CV_8UC1);
    warpAffine(image2, channels[1], M, image2.size());
    channels[1].convertTo(channels[1], CV_8UC1);
    image1.convertTo(channels[2], CV_8UC1);
    Mat merged;
    merge(channels, 3, merged);
    return merged;
(1,390 Views)
Hello, jungbinlee. It is not effective to send the whole code, because we don't understand what your code does. Can you explain the most important part of your code?
(1,269 Views)
