Machine Vision
Why do i get the error - Method Acquireimage of object DCWIMAQ failed
This message comes up when running my application when I am trying to aquire images. I have switched cameras and vision boards and nothing seems to help. The cameras are Analog RS-170 using BNC Connections.
(2,793 Views)
I would recommend looking at some of the shipping examples first. Try Hardware.vbp located in "...\National Instruments\MeasurementStudio\VB\Samples\IMAQ\1. Getting Started"
If this works, you should be able to port the code to your application. If it doesn't then you probably want to see if the camera is able to acquire images in MAX first.
(2,793 Views)
