Machine Vision
Why do images auto-scale the intensity and how do I disable this?
I am displaying an image from a FireWire camera (collected with "IMAQdx Get Image.vi") in an image indicator (Vision->Image Display) on the front panel. When the intensity distribution changes, the overall intensity seems to auto-scale. But if change the intensity in one part of the image and I put a cursor in another part of the image, the Image Information box tells me that the pixel value does not change even though the visible intensity of the indicator changes.
I have also made a comparison with the "good old" intensity graph. Then I have to use "IMAQdx Get Image Data.vi" and unwrap the data array before presenting the image in the intensity graph. If I turn off AutoScale Z, one part of the image does not affect the rest, but if I turn it on, the image behaves like the Image Display above. Evidently, there is some kind of auto-scaling in the Image Display.
Can someone tell me if and how I can turn off this auto-scaling?
(3,515 Views)
Double post.
Bruce Ammons
Ammons Engineering
(3,503 Views)
Other post with Bruce's answer is here
Best Regards
David
(3,485 Views)
