A few possibilities:
1) Does the image appear flattened when you acquire in Measurement and Automation? If so, you may need to change your PC's display settings to 24 or 32 bit.
2) Are you using the appropriate camera file? If your camera is a monochrome CCD, you should most likely be using the RS-170 camera file (CCIR in Europe). If you are using a color camera, then you should be using the NTSC camera file (PAL in Europe).
Please upload an example image file, so we can take a look at it.
What manufacturer/model of camera are you working with?
What program are you using to view your .png files?
-Robert Eastlund, Graftek Imaging, Inc.
Robert Eastlund
Phone: (512) 416-1099 x101
Email: eastlund@graftek.com
