Machine Vision
Why is the pattern tool unstable and not very repetitive
Pattern tool tends to jump around after training which causes the reference to move as well. Angle search settings are set at 0.  Any ideas, recommendations?
(3,047 Views)
I too agree. Try using co-ordiante system reference if possible.I find that to be more consistent
(3,005 Views)
in search angle have u tried giving +/-180 degrees?Though in certain image a search angle of 60 will yield a match and whereas 180 will not yield a match.May be a ni application engineer has some clue.
(2,973 Views)
