Machine Vision
Why rotated rectangle tool can't draw rotated ROI on image?
I want to use the tool window to draw a rotated rectangle on image, but each time, it seems only draw a rectangle, it can't rotate. Don't know why?
In Vision Assitant, if I use rotated rectangle tool, it will show like this:
Using the cross lines in rectangle, I can rotate my ROI, it is OK.
Run the sample code: C:\Users\Public\Documents\National Instruments\CVI\samples\Vision\2. Functions\Geometric Matching, change     imaqShowToolWindow (FALSE);
to  imaqShowToolWindow (TRUE);
on line 93#. Compile then run. Seems I also can't rotate my ROI, don't know why?
Please show me? Thank you.
Message 1 of 1
(4,548 Views)
