Machine Vision
Why vertical scrolling is appearing during grabbing with MAX
My digital camera supplies 40MHz pixel clock, 640x480 frame (with FE and LE controls) and 60 frames per seconds .
I am using the MAX utility to grab the camera video with the NI-1422. The Max capture the camera video, but the video is scrolling vertically on the acquisition window.
While I changed the scale parameter into camera prprperties to 2 (captures every second line and pixel)
the picture is decreased to 1/4 of the acquisition window and the vertical scrolling is stopped. Is there a problem to acquire and display 40MHz, 60 fps video?
While I am trying to Snap the video the MAX timeout error is occured.
(3,398 Views)
Alex,
It sounds like a timing issue. Hopefully the NI folks will be able to help you figure it out.
In the meantime, you might want to try reducing the height of your image by a line or two. I had a similar problem once, and that fixed it for me.
Bruce
Bruce Ammons
Ammons Engineering
(3,398 Views)
I tried to change the height of the image but it did not help. I tried to change other parameters in camera properties and it did not help. After that I changed the camera type, and found that one of the cameras configuration stops the vertical scrolling and complited Snap operation.
I tested all differences between my and camera *.icd files and found that SynchronizeEnables(Yes) line into *icd file causes vertical scrolling. After I removed this line from my *.icd file it solved the problem. Maybe you know what is parameter meaning?
(3,398 Views)
It sounds like you did a pretty good job troubleshooting. I am not sure what the parameter means. I think Enable is a signal that is sent to the camera, but I am not sure what it would be synchronized with.
Instead of deleting the line, I would probably change the parameter to No. Putting a comment explaining why you changed it helps also. I would also change the name of the file so it doesn't get overwritten if you upgrade IMAQ.
Bruce
Bruce Ammons
Ammons Engineering
(3,398 Views)
Hi Bruce,
Thank you for your comments
(3,398 Views)
