Machine Vision
X10 CM15a
I know this is an old post, but I would like to keep it going...  I'm just starting with this X-10 stuff, and this looks like the place to be.
Thank all of you!
Bob
Message 11 of 13
(1,336 Views)
How you guys are still on here??? Maybe you can help. I'm had a cm15a for probably 7 years and use it with an Iphone app called x10 commander. THis lets you use an iphone to control your devices with the cm15a plugged into your computer.
Now every few hours it stops working and commands don't work, unless I unplug the cm15a out of the outlet and wait a bit and try it again. It's gotten worse over time and didn't just instantly happen. But now I can only go 3-4 hours before it stops doing the commands. Ideas?
Message 12 of 13
(683 Views)
Hello Jackie,
Since this is a really old post, especially since it already has a solution, I think your best bet is to create a new thread.
Before you do that, I'd suggest including more information about your software suite and drivers you are using.
I'd also talk more about the behavior you are seeing. Is it timing out, are you seeing errors, or does it just not respond? What debugging have you tried so far?
I can tell you people will ask this straight away so if  you answer it in your first post you'll get more concrete responses.
Michael Pahl
Message 13 of 13
(664 Views)
