Machine Vision
XML file for EASYCAP USB frame grabber
I am trying to solve problem Error 0xBFF69011 - "Unable to get attribute" for EASYCAP USB frame grabber. Measurement and Automation Explorer is not capable to locate or generate XML file for this frame grabber in NI-IMAQdx. I have tried every possible described solution without success.
I have noticed that several people have managed somehow to use this USB FRAME grabber.
Is it possible that somebody send to me XML file for EASYCAP USB frame grabber?
I would like to analyse it and try to adopt it to my EASYCAP USB frame grabber.
Location of the XML file is usually: C:\Users\Public\Documents\National Instruments\NI-IMAQdx\Data\XML
Roman
(2,415 Views)
did you ever try to install this dvr driver into your system ?
also it is better to restart your max database from tool icon in toolbar of max it could helpful
(2,386 Views)
