Machine Vision
a strange phenomenon about PCI 1410
We let  our image grabber card working in EXTERNAL mode,  we connect a sine singal from a singal generator to the image grabber card,  then we get a strange image , it seems has only two value 0 and 1 .what's wrong?
(3,491 Views)
Hi Changle0204,
You connect the signal from the siggen to BNC of the frame grabber and set the image grabber card working in EXTERNAL mode?
Can you accompany your question with images of your camera setting and also the outcome?
Regards
- Meadow -
LabVIEW 7.0 - 2011, Vision, RT, FPGA
TestStand 3.0 - 4.5
(3,487 Views)
We find another problem :the Grounding Post on the IMAQ6822 is loosen , will it be the reason?
(3,481 Views)
we let the 1410 working in EXTERNAL mode , connect HSync VSync,Pxlk to grab card , a sine signal to video0.
(3,476 Views)
Do you have a timing diagram of what your sync, pclk, and video signals look like?  It looks to me like you are varying the input of the video signal during the clamping period, so the front end is getting very confused and not using the correct DC restore value.
(3,466 Views)
