Machine Vision
acquire and compare 2 images with a camera
Hey, i am working on an Image processing Project.
I want to take two Pictures with the camera and compare them. ich there are difference, i have to Highlight them.
First i want to Segment both Pictures into several Blocks and compare every block of each Pictures. I have a VI which can Segment a Picture into several Blocks, i will like to use it for two Pictures. can someone please help me to integrate the sencond Image as input, so that i can just compare the blocks?
(2,819 Views)
Hi moidrissou,
the short answer is that you can make this as complex as you like, but a very primitive version would be to load the second picture, divide them is as many parts as the first  one, and then simpyl substract them. if it reaches a certain threshold you would mark it. But this approach works only for similar pictures. if the images do not look alike a lot, then you have to think of some feature recognition instead.
But the simple code is added here.
Cheers,
Niko
Niko NR
Systems Engineer, National Instruments
(2,755 Views)
Hey,
Thank you for your reply. i will try to integrate it in my VI.
1) I want to know if there are any literatures i can use to compare two Images taken from camera at different times (t1 and t2) and highligh the parts of the seconds Images which are differents. which algorithm can i use to do this.
2) secondly if the Color of the second Image has changed, how can i recognised it.
3) Please if someone has an idea how i can developp it, just help me. I will like to recognise any Change: if a part of the new Image is missing, or if its Color (Contrast ?) is different.
The VI i have developped until now just tells me with a boolean Output if both Images (t1 and t2) are the same or no. now i want to Show the parts of the new Image which are different. after that i will compare the Color. may be you can give me so algorithm to use.
Thanks for your replies.
(2,740 Views)
