Machine Vision
add a grid to a bmp image
I'd like to add a grid over a bmp file (I use a firewire Bayer camera to grab a laser beam profile and to save it as bmp to my harddisk) but I haven't yet found a way to do it.
Does a way to do this exist? I use Labview 7 and NI-IMAQ 1394.
thank you for your help
(3,714 Views)
you can use the IMAQ Overlay Line in a for loop to create each line of the grid and then save it.
Best Regards
AmbuA
(3,695 Views)
I tried to overlay just a line, for now and to understand, but I cannot see any line in the output image.
I think the problem is the line's colour as i cannot set it; in detail:
I've an RGB (provided by a bayer filter) image with a black background (90% of the image) and a red foreground and I tried to set the white colour providing, as control, 255255255, as you can see from the attachment, but this didn't work.
What do you think about?
thank you again
(3,684 Views)
Mal,
You will need to use the Merge Overlay.vi before saving the bmp in order to have the overlay visible in your image. I have attached a screenshot of a VI that saves a bmp with a horizontal line across the center.
Nipun
(3,664 Views)
The white color, expressed as a decimal number is 16777215..(=$FFFFFF)
255255255 correspond to $F36E2D7 which is undefined and is interpreted as black.
CC
Chilly Charly    (aka CC)
(3,651 Views)
