Machine Vision
adding a webcam to labview on windows server
Hello Community, I am facing a huge problem.I have been doing FPGA development for a short while using the NI ELVIS II and the FPGA board and I am covering the basics such as the 4-bit, carry on full adder, 4 bit counter and the Shift register. I am trying to add a live visual feed during the excution of an experiment using a Logitech USB-Webcam C510. However, as it turns out, there are no support drivers for Windows Server 2003. Any way I can go about this without having to write a  driver all on my own?
(3,003 Views)
Hey rbesiga,
Can you explain a little bit more what you are doing? and how you are doing FPGA development on the ELVIS II...
A. Zaatari
(2,989 Views)
