Machine Vision
any NI products support dalsa CA-d6-0512W
Hello:
Just want to if Dalsa CA-D6-0512W is supported?
(3,274 Views)
This camera is not supported by NI. There is not a NI framegrabber that supports it and also there is no camera file associated with the camera. If you are looking for a camera that is supported by NI you can go to ni.com/advisor. Click on the camera advisor. There is a search engine that allows you to select specifications that you are looking for and then will show cameras that fit that description. Some cameras on this site are not supported by NI. To make sure that it is supported select the camera and this will have a page that recommends NI hardware and also will have a section for a possible camera file. If both of these are fullfilled then it will be supported. Good luck on your search. Have a good one.
(3,274 Views)
dcourtri, do you know why this camera is not supported? Is there anything special about it?
(3,274 Views)
