Machine Vision
auto start inspection on remote target using vision builder and smart camera
I am trying to automatically start a remote inspection on vision builder startup.  I have been able to autostart an inspection stored on the local machine, but when I try the same method on the remote target it does not work.  It seems the problem is vision builder always defaults to the local target on startup.  Is there way to default to remote target?  I have tried the Tools->Remote Target Options->Startup configuration and this didn't seem to help.
(3,162 Views)
Unfortunantly, the Vision Builder autostart feature does not have the capability to change the default to a remote target. The autostart will default to the local machine as you have found.
Vince M
(3,129 Views)
