Machine Vision
autofocus
how can I use vision libraries to create a autofocus algorithm for an image acquired with a microscope?
thank you very much
fulvio coppola
(7,616 Views)
I think autofocus has been discussed a few times before.  You might want to search for more detailed responses.
The simplest method is using one of the edge detection routines followed by a quantify image.  The standard deviation of the edges gives you a great focus indicator:  The larger the value, the better the focus.
The difficulty with a microscope is that frequently there are several layers that come into focus at different time.  This focus indicator gives you a peak at each layer.
Coordinating the focus indicator with control of the focus is a little more challenging.  You need to scan the possible focus range and find the largest value of the focus indicator, then repeat with a finer motion control.
Bruce
Bruce Ammons
Ammons Engineering
(7,610 Views)
thank you very much
best regards
fulvio coppola
(7,595 Views)
I consider myself a newbie with LabView, but I hope I can get some answers.  Here it goes.
I have a measuring microscope with X & Y stages driven by drive motors.  The CCD camera and objective lens assembly are mounted on a stage with the focus (Z-stage) and magnification stage driven by step motors.
My objectives are the following:
-Add autofocusing capability to my existing VI, such that the image will focus on a user selected region of interest (ROI).
-Calculate the depth between two part features that appear in separate ROIs.
Any assistance would be greatly appreciated!!!!
(6,210 Views)
It is not going to help if you are going to leave a message in a lot of threads. It is just going to delay you in getting a proper response. Stick to a single thread.
(6,197 Views)
Continued here. And please keep everything in that thread only
(6,181 Views)
