Machine Vision
avi2 not working with queues
I have a problem with using the histogramcolour function and also the avi functions. I'm using these with producer consumer architecture where by i read each frame of the video using the avi read frame function and then queue this to the consumer and it works fine. however i tried to change the avi functions to the avi2 versions and this stopped the program working. i now get an error at the imaq histogramcolour function with a possible reason saying imaq vision: not an image. why would it work for the old version of avi functions but not the new ones?
does anyone know what the problem is? Ive attached the vi
Labview 14.0, Labview 12.0
CLAD
Mechanical Engineering Student
Message 1 of 22
(4,813 Views)
I test this
it work
test this
and  tell if it work for you or not
Message 2 of 22
(4,799 Views)
i cant open it because I'm using labview 14. I also can't update to labview 15 because I'm using a university pc. is there another way i could run it. what did you change?
Thanks for the help 🙂
CLAD
Message 3 of 22
(4,781 Views)
Message 4 of 22
(4,778 Views)
nope same error as before. I tried to run it with the avi file i have and also the image that was loaded of the balloon. would didnt work.
CLAD
Message 5 of 22
(4,776 Views)
did you test this vi with labview example avi file like balloon?!
also check this link about the codec and if it not work yet you have to repair you vision toolkit
https://www.ni.com/en/support/documentation/supplemental/21/avi-codec-support-with-avi2-in-ni-vision...
Message 6 of 22
(4,771 Views)
i dont have access to the ballon avi file. in the national instruments folder at my university there is no vision folder and thus no avi example files
CLAD
Message 7 of 22
(4,766 Views)
I just tried using a random avi file that i downloaded from the internet and the same problem occurs. Error - 1074396120
CLAD
Message 8 of 22
(4,765 Views)
use these to test
Message 9 of 22
(4,759 Views)
Message 10 of 22
(4,758 Views)
