Machine Vision
basler Camera Compatibility
i have planned to buy acA1300-200um Ace Series USB 3.0 Monochrome Camera and i need to know that LabVIEW can access all the parameters of camera such as hardware triggering ,frame rate etc.. . mainly i need to know whether hardware triggering of specified camera can be done through LabVIEW ?
LabVIEW version used 2012 or 2013.
(4,792 Views)
Yes, I work a lot with the Basler ace cameras. They are nicely compliant with the standards and expose all the functionality.
You need a license of Vision Aqcuisition system though..
(4,775 Views)
I have bought basler acA 1300-30uc after your reply but i cannot able to access all the parameter in labview. only thing i can access is gain and exposure.
(4,731 Views)
You have the camera associated with the Basler driver, which provides a DirectShow interface that IMAQdx is using. This limits access to many features. You should either uninstall the Basler driver or switch the driver in device manager for the camera over to NI-IMAQdx's native driver.
(4,723 Views)
