Machine Vision
c-cam
I need to use a C-Cam 14 Mp camera: FCi4-14000
http://www.vector-international.be/
I think the PCI-1426 or PCIe-1427 would be good choices for this camera.
It's a fairly new camera, didn't see it in the list of supported cameras and wanted to ask if anybody else has used this combination and how well it worked.
thanks...
(3,679 Views)
Hello bob,
Since it is a fairly new camera, I am not surprised that it has not made it on the supported cameras list.  After looking over the data sheet I see no conflicts between the camera and the boards you mentioned.  Are you using the Bayer version of the camera?  If so, there is a good chance you won't see color images in Measurement and Automation Explorer (MAX), but using a couple of simple Bayer Decode VIs in LabVIEW or a function in another language, you will see color.
Carlton
CLA
(3,662 Views)
Thanks for the help.
What distributors might have one of these boards in stock.  We've ordered one from NI, but the stock is in Hungary and will take a week to get here if it makes it through customs with no hitches.
thanks...
(3,645 Views)
One of our alliance members, Graftek Imaging, sells the PCI-1426 and PCIe-1427 so you may give them a call if the framegrabber cannot arrive fast enough from Hungary.
Carlton
CLA
(3,630 Views)
