Machine Vision
calibrated value of radius for find circular edge
I am developing a vi to measure the radius of the circle by using find circular edge option available in IMAQ Vision development.
The radius measured is in pixels, If I use simple calibration before find circular edge and try to read the calibrated value the value is not reading in required unit.
If the calibration is done to measure straight line instead of radius of circle the measurement is obtained in calibrated value.
Is there any change required to read the radius in calibrated unit.
Message 1 of 1
(3,033 Views)
