Machine Vision
calibration info not being saved in the image
hi,
           I have developed an application to calibrate my system used for inspection. When i run it on my development PC (having labview PROFESSIONAL DEVELOPMENT SYSTEM) it stores the calibration info in the images properly and measurements are ok. But when i deploy this exe on host PC of the inspection system , found that the calib. info is not being saved. what couls be the problem
regards,
yashpal.
(2,975 Views)
Hi Yashpal!
Are you saving the corrected images after the inspection?  Do you see the difference in LabVIEW or by viewing the images afterward?  Finally, did you install the NI Vision Run-Time Engine on the inspection PC? There are two possible causes for the unexpected behavior you are seeing:
1. The Vision Run-Time Engine is not installed on the inspection PC.
2. The file structures are different on the two PCs and LabVIEW expects an image to be in location that it is not.
Chris Bolin
LabVIEW Partner Program, CLA
(2,955 Views)
