Machine Vision
call Template Editor in LabVIEW
Is it possible to call template editor in LV? I searched around and found using command prompt is asolution, but is there any VIs or a combination of VIs that can realize this function in new version Labview?
Following is the link that calling template editor using command prompt:
http://forums.ni.com/t5/Machine-Vision/call-template-editor/m-p/1081416/highlight/true#M27206
Thanks for your kind help!
(7,180 Views)
do you really need the template editor? Why don't you create your own "template editor" in Labview (it can also be as a popup dialog)?
K
https://decibel.ni.com/content/blogs/kl3m3n
"Kudos: Users may give one another Kudos on the forums for posts that they found particularly helpful or insightful."
(7,166 Views)
I know, but i just want to confirm that if there's some VIs present, which is much easier
(7,158 Views)
you can open the tempate editor via the command prompt.
Save the templates on disk and read them in your Labview program.
K
(7,153 Views)
Hi check this one out
forums.ni.com/t5/Machine-Vision/call-template-editor/td-p/1081416
Best Regards
(7,147 Views)
i already read this note, and it seems that this is the only way to call the template editor in LV, thanks all the way !
(7,143 Views)
where the problem can be found.
(4,910 Views)
