Machine Vision
cam problem
when i use vision builder and aquire acam after converting the program to labview if i make any changes "using arduiino for example" it gives me error9999 &the cam doesn't work any help please
(4,632 Views)
I have the same problem. please, if any one has a solution, reply quickley.
(4,621 Views)
هى كويكلى كده يا مايل
(4,596 Views)
Ayman,
Can you please provide more detail surrounding this issue? What are your software versions of both VBAI and LabVIEW? What changes are you performing? What actions lead to this error?
Huntington W
***Don't forget to give Kudos and Accepted as Solution where it is deserved***
(4,587 Views)
