Machine Vision
camera discription file
I just installed a Jai CV-M50 camera in combination with a PCI-1408 board,
this combination is also used in the 1400 package.
Who can deliver me the camera discription file (icd-file), because i'm not
succeeding in getting a proper image out of the camera.
(5,285 Views)
Luc,
The CV-M50 is an analog camera with a standard output. There are two "flavors"
which are CCIR and RS-170. RS-170 is a standard used primarily in the US
and Japan whereas Europe typically uses CCIR. The National Instruments driver
chooses RS-170 as the default. Since you are located in Europe, chances
are that you have the CCIR version of the camera. To fix this problem, go
into the Measurement and Automation Explorer and select channel 0 of the
1408. Right click on the channel and select Camera>>CCIR. You should now
be able to acquire images.
Sincerely,
Tony Iglesias
IMAQ R&D
"Luc Beysen" wrote:
>>I just installed a Jai CV-M50 camera in combination with a PCI-1408 board,>this
ckage.>Who can deliver me the camera
discription file (icd-file), because i'm not>succeeding in getting a proper
(5,285 Views)
