Machine Vision
camera file for ec16000
dear all,
I am looking for the camera file for Pricenton Instrument EC16000. (http://www.princetoninstruments.com/products/imcam/megaplus/#7)
I have purchased a NI cameraLink framegrabber ni pice 1427.
I also downloaded NI camera file generator, but am not really sure how to produce the camera file from there.
Does anybody have such a camera  file?
thank a lot...
(3,986 Views)
This camera file is not provided.
When you say you're not sure how to use camera file generator, can you explain what is the problem you face so that we can offer you a help, but generally, you need tyo open camera's specification, and fill in data to camera filew generator one by one.
If you're not sure with some information, you may need to check back with camera vendor.
(3,964 Views)
Accepted by topic author Larry Liu
thank kate.
i ve got the camera file from the vendor....
see attached. (note this one is for gray image, not for RGB version). It is a txt file. please save it as '.icd' file before loading it in your MAX.
(3,927 Views)
Larry liu,
thanks for sharing it. That might help some one.. :smileyhappy:
(3,914 Views)
