Machine Vision
camera has been removed
我用labview2017 +vdm2017+vas 2017  程序运行1小时左右 所有相机提示报camera has been removed 错误,请问这是什么原因导致的要怎样解决
(2,555 Views)
-Do they work in NI MAX separately fine or they give same error?
-Is this always occurs after same time and for same cameras(How many are you using?)?
-Did you try changing the cables and ports and PC and still same issue?
-What camera make and models you are using?
-If USB: Try unchecking the option "Allow the Computer to turn off this device to save power" under USB Connections in Device manager.
-Some additional info: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P8jKSAS&l=en-IN
-What is the resolution you are trying to capture at and which version of labview are you using?
uday
(2,544 Views)
