Machine Vision
camera selection for screw thread analysis
In the Imaging source website, I haven't found any 5MP Monochrome Camera,
Please see
Message 11 of 28
(2,712 Views)
I didnt suggest it for a 5mP camera but for price comparison. Check this
Message 12 of 28
(2,709 Views)
Yes, I found a progressive scan camera in the list (5MP)...Thinking that it might be useful.
Between, if my object size runs between 1 inch to 4 inch, what do say, how much I need to be the FOV for a good analysis.
Message 13 of 28
(2,673 Views)
Size of smallest distinguishable Feature(edge)  = (FOV/Sensor Resolution) x 2.
Message 14 of 28
(2,671 Views)
My smallest size will be 25.4 mm,
I believe resolution means, resolution for the camera which I am going to  selected (2592 x 1944)(H*V) or is it  sensing area 5.70 x 4.28mm
Then FOV= smallest size/2 *senson Resolution
FOV = 25.4mm/2*2592
Am i correct?
Message 15 of 28
(2,670 Views)
Check here. Leaving for the day now.......
And this
Message Edited by muks on 04-13-2010 06:22 PM
Message 16 of 28
(2,668 Views)
What is the smallest measurement you need to make?  For example, if you want to measure something within 0.01 mm you need 2 pixels=0.01 mm.
If the wide side of your FOV is 25.4 mm, the min sensor resolution in that direction is 25.4mm/(0.01mm/2) = 5080.
Going in the other direction with the 5 MP sensor, 25.4mm/2592 = 0.0098mm/pixel.  The smallest measurement you can accurately make is 0.0098mm*2=0.0196mm.
Bruce
Bruce Ammons
Ammons Engineering
Message 17 of 28
(2,652 Views)
Have you finalized the FOV,WD and lens?
Message 18 of 28
(2,609 Views)
I decided a horizontal Fov of 30mm and Vertical filed of view as range between 30-70mm
Working distance as 200-300mm
Decide the lens as http://www.edmundoptics.com/onlinecatalog/displayproduct.cfm?productID=1546&PageNum=1&StartRow=1
Planning to buy AVT guppy camera-F503B(Mono chrome), suggested by the team. I hope this will work. Did you see any disadavantage for the AVT guppy.
Message 19 of 28
(2,608 Views)
COST......... :smileywink:
Message 20 of 28
(2,606 Views)
