Machine Vision
camera type
my application is to use labview and vision builder to know if all the electronic components of aboard does already exisit on it
what type and rsolution and other features of the camera ican use ?
if i will generate only one digital signal do i need to use data acquision?
(4,211 Views)
It depends upon Area you want to cover, height of the camera and the size of smallest component.
No, its not needed, Cameras comes up with Digital I/O you can use of them.
Silver_Shaper | CLD
(4,200 Views)
thks
if iwant to dect a board of tv for example 25*25 cm the height is under control ican put it at 50 cm height
ـــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــ
for the output it will be from labview program to a plc or micro not the camera . just one digital signal
(4,188 Views)
I believe this article will help you calculate the parameters you are interested in.
Calculating Camera Sensor Resolution and Lens Focal Length
Isaac S.
(4,175 Views)
