Machine Vision
camera with usb 3 vision specification not recognized by MAX
Has the USB 3 vision specification been implemented in the 2013_08 vision acquisition software, and if so what steps do I need to follow to have a USB 3 camera recognized by MAX?
I have a Ximea MQ042CG-CM camera which should be compliant with the USB 3 vision specifications.  I am trying to use the camera with Labview for object tracking, but it is not being recognized as an imaging device.  Just a few days ago the camera was recognized as a Direct Show compliant imaging device, but I updated the API for the camera and apparently the support for the Direct Show specifications has been removed.  This change is fine as far as I am concerned because I want the camera to operate as a USB 3 vision device rather than direct show, but I need to find out how to make the MAX recognize the camera.
Thank you for your assistance.
(4,699 Views)
Yes, Aug 2013 does:
http://www.ni.com/white-paper/14308/en/
Setup process is here:
https://www.ni.com/en/support/documentation/supplemental/16/usb3-vision-cameras-and-ni-real-time-tar...
I have not research this topic in depth.
-AK2DM
(4,692 Views)
Double-check that the firmware you have is compatible with the USB3 Vision spec. These models were first shipped before the spec was finished and so if you do not have a new enough firmware it is quite likely it would only be compatible with their own API.
Based on http://www.ximea.com/support/wiki/allprod/XiCOP it looks like the provide a utility to update the firmware.
Eric
(4,685 Views)
