Machine Vision
can i use the parallel port for trigering a usb cam?
I m trying to use the parallel por like a in/out interface in order to control a automated vision inspection system, so i need 1 in and 2 out:
In is a triger for the system
Out are: A green led for the ok result and a red led for a nok result
I have read in the developer zone and i have sennthat is possible but i need a bit of help.
For example i must to know if is necesary to protect the port and what is its working voltage and max intensity.
And now i need how to programe it in labview, i m adquiring the image with the webcam and i want thet when i press a real buton i snap a picture,
Please help me if you know
Maintenance and production management studient.
Fernando Mora Torrijo
Zaragoza (Spain)
Spanish studient
(2,967 Views)
Hello people:
None can help me? I only want to learn.
Thank you, i need you
Fernando Mora
Spanish studient
(2,949 Views)
