Machine Vision
can the white and blacklevels on a 1408 be set for individual channels independantly
Yes. You need to create separate camera files for each channel, though. If you use the same camera file on different channels, they have to have the same settings. Just use "Save As" to create a copy with a different name.
Bruce
Bruce Ammons
Ammons Engineering
(3,378 Views)
