Machine Vision
change to another classifier file
I made a program for classifying objects using Vision builder for Automated Inspection 2.6.1. When I made it I hooked it up with a classifier file I made at the same time. Then I migrated inspection to labview code. The problem now is that I wish to change to another classifier file. When I change the path from the original classifier file to another it still classifies as if I had not done anything.
You might wonder why I just don’t do It again with Vision builder for Automated Inspection 2.6.1. but my school for some reason left out just that program from the deal they had with NI after x-mast.
I hope someone can help me with my question and I hope I am specific enough. I’ll attach the program if anyone wishes to take a peek. I’ll also attach 2 pictures pointing out my problem. Hopefully someone out there has had the same problem as me and knows the answer.
Kyrre
Inspect main is the main file
Message 1 of 1
(3,024 Views)
