Machine Vision
chromatism inspection
We want to inspection the chromatism of leather,fabric . Could you please introduce what method and the software/hardware should be used ? Your advise is highly appreciated . Thanks.
David Lee
(3,437 Views)
David,
I would suggest you take a look at some of the options listed at the web site link
Vision link This is definitely something you can do with many different combination of NI software and hardware.
A. Talley
Applications Engineering
(3,437 Views)
Due to be a beginner for machine vision ,so I would like now the basic construct steps and which functions can be used. we have had a set of standard color code card ,now want to compare the difference between the standard and the practicality. Please give a solution . Thanks.
David
(3,437 Views)
A little more detail about the application and the details you are inspecting would be useful.
Whenever you are trying to inspect color, good lighting is a major issue. I would also recommend a digital camera for acquiring images. Colors tend to bleed a lot when using an analog camera.
If you are trying to make absolute color measurements, you will have to do a lot of color calibrations to get good measurements. If you just want to compare color to a reference sample, that is much easier.
Are you looking at overall color or small spots that are a different color than the rest of the material, or both?
I think what you need to do can be done in LabVIEW with the vision toolkit, but I would need more information before I could make any recommendations.
Bruce
Bruce Ammons
Ammons Engineering
(3,437 Views)
