Machine Vision
color system in Vision Builder
I would like to ask about color system measurement in Vision Builder.
I would like to ask what is the observer angle used in the color system in Vision Builder, like XYZ or L*a*b*. Is it 2 degree or 10 degree?
Can we select the angle (2 or 10) when we measure color?
Thank you very much.
With my best regards,
Panmanas
(3,659 Views)
Hello panmanas,
The observer angle used in all NI-VISION software is 2 degrees. There is no way to specify a different observer angle.
I hope this helps you out!
David G
Sales Engineer - SE Michigan & N Ohio
(3,622 Views)
Dear David G
Panmanas
(3,612 Views)
