Machine Vision
color table / palette of clusters with more than 256 elements for each color
I want to image arrays with values up to 1023 for each element. So I want to create a greyscale color table where 0 is black and 1023 is white. Is that possible?
Which function in Labview 7.0 (including Labview Vision) can display my data?
Thanks!
(3,316 Views)
the ArrayToImage function can convert arrays of u8, i16 or floats to images. For values 0 ... 1023 (10 bit) you can use the i16 with a little conversion. I have attached a vi, that shows how. It's required, that you have imaq vision installed.
Kind regards,
Philippe Goetz
Applications Engineer, National Instruments
(3,300 Views)
