Machine Vision
colour to grey scale and crack detection
One suggestion would be switching to a grayscale camera.  There is no reason for a color camera to be used in this application.  It would improve the details in the image.
Will real cracks look like this?  These look like a notch was cut in the rail with a radial saw.
Brighter lighting might improve the contrast between the rails and the cracks.  It looks like the cracks will be black no matter what, so with high enough contrast you could pick them out fairly easily.  Using a vertical edge detection matrix in the convolution vi would probably highlight the edges nicely.  Something like:
1 1 1 1 1 1 1
1 1 1 1 1 1 1
1 1 1 1 1 1 1
0 0 0 0 0 0 0
-1 -1 -1 -1 -1 -1 -1
This would highlight the top edge of the crack without highlighting much else.  Perhaps after that you could use a fixed threshold and see if any crack segments show up.
Bruce
Bruce Ammons
Ammons Engineering
Message 11 of 15
(1,820 Views)
Hi sailesh,
I tried something on your images. You can optimize it further.
Message 12 of 15
(1,791 Views)
Did the vi help?
Message 13 of 15
(1,692 Views)
any update?
Message 14 of 15
(1,626 Views)
I need to extract the crack alone in the image of a cracked egg, please kindly help me on this .
Message 15 of 15
(999 Views)
